hi
I create in form salestable exacctaly in salesline an realedit it is not field in database it take a resultof devision for exemple:
real q,c,f ;
q=c/f;
realedit.pastetext(num2str(q,0,0,0,0),false);
the realedit take the result but when i create another salesline all the line take the new result why ?
how i can resolve this probleme ?
thank you
Where did you placed this code?
Did you place the display method in the grid of the SalesTable form? Maybe you can add the field in a pageTab en try again.
I put this code in “textchange” “modified” and “lostfocus” “gotfocus” of salesQty Field in form but it give the same result
real q,c,f ;
q=c/f;
yes I do But it don’t work too and give somme bug when I click to add new record
