Form must get open till NAV is open...
Dear All,
i am just doing some RND in nav… so i just want to open a welcome form at the time of NAV opening and that form must open till NAV did not closed, (welcome form must not close in any other case)
What i did for that is following::
  1. ) I Open that welcome form at Codeunit -ApplicationManagement → CompanyOpen()
Welcome.RUN;
and use this Codeunit as single instance
2.) Now second thing i have done on Form - OnQueryCloseForm() : Boolean
Exit(TempClose) — TempClose is a boolean variable
I have created a function also
UpdateFormClose(Temp : Boolean)
TempClose := Temp;
CurrForm.CLOSE;
3.) Last thing i have done at again in Codeunit -ApplicationManagement → CompanyClose()
Welcome.CloseForm(TRUE);
I also check that at the time opening – CompanyClose() function get execute first then CompanyOpen().
Please let me know what i have missed in these steps, Welcome form get open now but problem is i am not able to close neither NAV nor form.
Do you have any solutions about your problem? I would like to realize something similar. And I have nearly the same code as you have.
Rolf
