I have been asked to put a total count of say part numbers for example when someone opens the Item card in list view. Down at the bottom of the list view form where it says OK, Cancel. etc… it would have total number of parts in the Navision table 27.
So I’d start with Text Box - On trigger. I’d need a Global variable. Reccount numeric. Maybe reccount: =reccount + 1;
You will have to code this. Off the top of my head you could create a variable for the record you are using. In the onaftergetcurrrecord trigger - filter the record variable to ‘…’+CurrentRecord and then display the count of the record variable as the “5000” records.
