SPN-AX
January 13, 2009, 4:28am
1
hi all,
when i click to open this Form and get this error message. i look and cant tell what is wrong with my Form.
Message (22:24:35)
Error executing code: Wrong argument type for function.
Stack trace
(C)\Classes\FormRun\Run
does anyone know what it is complaining about ? Thank you very much.
can u tell, regarding which form you are talking about.
Explain the name of the form, from where are you opening this form , either from AOT or from Main menu??
SPN-AX
January 13, 2009, 3:41pm
3
either from the AOT or Main Menu, when i click to run, it gives me the same error. let me know if you know what it is. Thanks so much.
SPN-AX
January 13, 2009, 8:17pm
4
Please disregard my post. i’ve figured the error out. Thank you all.
Shannon
February 10, 2009, 10:03am
5
I have the same error and I have already compiled and compiled forward the classes mentioned in the stack trace, but it did not help.
SPN-AX, since you have figured the error out, can you please give me a hint how to solve it?
\Classes\FormRun\run
\Classes\SysSetupFormRun\run - line 4
\Forms\SalesGroupInvoiceCT\Methods\init
\Classes\SysSetupFormRun\init - line 3
SPN-AX
February 18, 2009, 3:15am
6
hello Mykola,
i am so sorry that i havent checked the forum for a while. The error that you are having is because: super() is called after your codes in your init() method.
put the super() method before your codes then you should be fine - like before your first " if " statement or something. Thats what i did with mine and it worked just fine. let me know if this fixed your issue.
