form control modified
how to check form control is modified or not in ax 2012
Could you please spend a little more time explaining your problem? Your current question can be interpreted in several different ways.
Have explained the issue in the next post. kindly go through that…Hope I will get the answer from u…
I see you’ve created a new thread (How to check which form control has been modified ?), therefore I’m locking this one.
