Hi, Does anyone know how the Item description gets onto the title bar of the item units of measure form 5404 (look-up from Item Base Unit of measure)? Brain teaser for you! No prizes for first to get it right though, just respect![8D] Jon
It is linked to the Item form, via the Lookup so it takes on it’s Parent’s Caption, if you run the form in design it will just say “Unit of Measure” ![8D]
David is basically right. If you want to know more, go to the C/Side Reference guide, and have a look at the property description for “DataCaptionFields”. That explains it in detail.
