Please could you tell me why the transaction ‘Residual caused by rounding of Additional Currency’ is posted? There are thousands of these lines all at zero value.
HI Andrew,
Check the settings on the reporting tab of the currency the transaction is about. It’s because you are using the Additional Currency functions.
They are created whenever a currency transaction is created, that has a rounding. They only have a value in the additional currency, not in your primary currency. If you “zoom” in on the g/l entries created, then you will see both amounts.
So why are there hundreds of entries for zero amounts ?.
A
Because this rounding does only effect the “additional currency”, not the currency you are actually using as your primary.
Here is a link with a bit more information on using the additional currency functions:
https://msdn.microsoft.com/en-us/library/hh168995(v=nav.90).aspx
