Can anyone explain for me whats the meaning of the words as per below
1). forcePlaceholders
2). forceSelectOrder
3). forceNestedLoop
- forceliterals
Regards
AK
3). forceNestedLoop
Regards
AK
ForcePlaceholders
ForcePlaceholders instructs the kernel not to reveal the actual values used in
“where” clauses to the database server at the time of optimization. This is the
default in all non-join statements. The advantage of using this keyword is that the
kernel can reuse the access plan for other similar statements with other search
values. The disadvantage is that the access plan is computed without considering
that data distribution might not be even, or that the access plan is an “on average”
access plan
ForceLiterals
ForceLiterals instructs the kernel to reveal the actual values used in the “where”
ForceSelectOrder
This keyword forces the database server to access the tables in a join in the given
order. If two tables are joined the first table in the statement is always accessed
first. This keyword is frequently combined with the “forceNestedLoop” keyword.
ForceNestedLoops
This keyword forces the database server to use a nested-loop algorithm to process
a given SQL statement that contains a join. This means that a record from the
first table is fetched before trying to fetch any records from the second table.
Generally other join algorithms like hash-joins, merge-joins, and others are also
considered. This keyword is frequently combined with the “forceSelectOrder”
keyword.
And Atul for more Information opn this you can refer DEV 3, Chp - 2, In Ms Dynamics Ax 2009: Development Introduction.
Hope this information will help you…
Thanks Jasmine…[:)]
