footer more than once?
Hello! Based on the number inserted in RequestForm that many times i want to print some section in report (it has to be at the bottom of the page). If i use Body section this works but it’s not at the bottom of the page,if i use footer section it is at the bottom but it gets printed only once… How could i fix this, is there maybe any other option to print at the bottom of the page without footer section?
Have you tried the TransFooter Section? According to the Application Designer manual, a TransFooter prints before a page break. You may also have to set the PlaceInBottom property to Yes.
Hy prosen im not shure … but have you tried “transfooter” section? Bye(Stefan);
Opps beat’n by david, he was 00:01:20 faster…
