How to easily identify flowfields in a table with alot of fields?
Thank you
Thank you
Use the “Field Class” column.
Hi Imran,
Once again, Erik is right! You can display the Field Class property in the Table Designer window using the Show Column feature.
One other process that I’ve found helpful is to build a form object based on the system table Field (t_2000000041). You’ll see pretty much the same information that you get in Table Designer (without the design features, of course), but you also get the advantage of being able to see all fields in all tables at the same time, and you can filter on any of the columns to isolate records based on Name, Type, Class, etc.
Thanks that was easy :).
Solved the issue, thanks Erik.
