Hi, all
I’m facing the following problem in Dynamics 2009 R2 Classic, sqlsrver, database 5.0 converted.
On Purchase Header (38) I’ve added a flowfield based on a customized table. The flowfield is shown on the Purchare Invoice form. When the user enters a value on a certain field, which is the key to calculate the flowfield, this should be updated. Easy, no?
Well, no. The form (51) has the UpdateOnActivate property set to Yes (as all the form of this kind have) and the only way to see that damned flowfield to show the correct value is to click on a line in the subform and then click back on the header.
Nothing of that I’ve tried so far (CurrForm.UPDATE, CALCFIELDS + CurrForm.UPDATE, CurrForm.ACTIVATE) seems to work.
Any idea, guys and gals?
Thank you
Anna
