dear all:
after setting the datefilter on the g/l account form, the net change field amount is not the same with the total amount of drill down, could anybody can suggest why? thanks in advance!
dear all:
the net change filters on posting date of gl entry after u apply the date filter… how ever balance field will not filter…
after drilldown it shud show the same total entries… please check the flowfield properties otherwise.
Anil.
Welcome to DUG!!!
Check the proprerties of flowfield field
Is anybody change that ??
the field properties of net change field is not changed
one account 's net change is more the other account’s net change is less, and the two balanced. the remaining accounts are ok
net change is based on the date filer… however balance amount will not consider date filer… so please check ur filters
not balance field, but just net change field
Then you need to throw us example… if your filters are proper… then u will not face any issue with the drilldown… total and netchange value
Anil
