FlowField for showing and selecting values ?
hi, i have a table with a flowfield so i can see more info out of another table using an id in both tables … when i want to add a new record i would like to fill the id field using this lookup field so the user does select with the flow-field instead of the flowfields … it is important that the user does not see the id field … he should work with the flow field showing the description … hope you understand my problem :slight_smile: thx for help *** quack ***
mmmh i think my description is a little bit confuse :slight_smile: … so once again … i need a field which shows me the description out of antoher table if another field with an id is filled … if i want to add a record i will select the entry (exactly the id) using the field where the description is shown as a lookup field showing me all possible records… is this possible or not ? *** quack ***
Hi Alex! I think your description is still a little confused … Let’s try it in the german forum !?! Regards, Jörg Joerg A. Stryk Apollo-Optik, IT/ERP
yes it is not described very well … but i solved my problem in another way so now it works like i want … thx for your attention :slight_smile: my next prob will be more simple … *** quack ***
