I create a new flowfield ‘unit cost’ in transfer shipment lines table, it look up the ‘unit cost’ field in the item table, when run the transfer shipment line table, it only display 2 decimal place, while i want to get more exact figure, say 5 decimal place(in item table, there are many decimal palces).
there is another way to do this in NAV: Set the AutoFormatType property to 2 and leave the DecimalPlaces property at its default value. This advises NAV to use the decimal places for unit amounts as set in the G/L setup. The advantage is that if you decide to change the unit-amount decimal places allowed, it will affect your field as well.
