Flow field reference to other table
I have the following situation I am hoping someone can assist me with.
I need to create a new flowfield on the customer table. It is a sum on the amount field of the g/l account field. The table filter filters the g/l entry table for source type = customer and source code = customer.“no.”. I also need to filter for a particular G/L Account. Obviously I do not want to hard code this in the table filter (using Type = CONST) so I have added a field to the S&R Setup table in which the user can enter a g/l account no. I would then like to use Type = FIELD or Type = Filter to set my table filter.
I want to use this account no. as a filter in the flow field table filter - but as the flow field is on the customer table and you can not reference another table or use a variable in the flow field table filter, I am stuck.
My CalcFormula is currently Sum(“G/L Entry”.Amount WHERE (Source Type=CONST(Customer),Source Code=FIELD(No.)))
Any suggestions on a way to achieve this?
Thanks in advance.
Craig
I guess flowfield wouldnt work, you have to write the code for the filtration and the sum.
Sure this is pretty straight forward.
One thing many developers don’t realize, is that a flow field can be used as a part of the definition of another flow field. I use this quite a lot. Its especially useful since you only need table designer and form designer, no code required.
In your case just create a new flow field called “Sales G/L Account” and this is a LOOKUP to the field in the S&R table.
now just add this field as one of the components in the SUM formula that you have.
LOL! I had thought of doing this but had discarded the idea as I was sure you could not use a flow field in another flow field. Goes to show you should never assume you know anything!
Thanks David.
As a matter of interest, and in case anyone has a problem with this, when displaying the resulting flowfield on a card form I had to do a CALCFIELDS in OnAfterGetRecord which is normally not required when displaying a flowfield on a form.
Cheers
Craig
Never say never with Navision. [:D]
Also with the calcfields, you could put both fields on the form, which will then calculate them correctly just make sure that the first field has a lower control ID than the second, or it can get a bit confusing in List forms sometimes.
