fixing dimension on posted documents
We have posted a purchase invoice for a project X for 100 pcs item .
However after posting it turned out that 40 pcs should have been assegned onto Project X and the rest to Project Y.
How can I fix this without posting a credit memo?
thank you!
Gabliver
The quickest way remains CM + corrected PO.
Another option, that corrects ONLY GL entries Dims, is creating a General Journal with lines that roll back the postings for incorrect Dims and recreate new entries with corrected ones. All other ledger and document entries will remain as they were under such scenario, they will be out of sync with GL regarding to Dims.
This can be acceptable if only GL analysis by Dims are done, Item analysis by Dims by no means will be incorrect.
In fact, out there exist addons that are designed to correct DIMs for posted transactions, but those I have heard of worked with old Navision versions, I don’t know are they updated to handle the new method of how dims are stored in the latest versions (Dimension sets) .
