Fixed delivery date for special customers
Hi All
Is there a possibility to set a fixed delivery date for customer for example a customer always wants his delivery off items on a thursday
I think NO, you need to customize…
can’t you use a personal base calender for this customer? The shipment date etc in the sales line will react on this calender.
I tried this solution once (in a 5.0SP1 ), and it worked, but the only problem was that the same calendar is used for calculation of the delivery period. or is something changed on that in NAV2009 ?
kind regards
i believe so because these dates are connected to eachother.
Hi
I tried this with a basecalender and it works okay, so problem solved, thanks for you input :slight_smile:
