Has anyone set up the fixed asset depreciation to work on leasehold improvements ie… over the life of the lease where different improvements happen at different times. All improvements should expire the same date even though started on a different date. Admin: Moved to: NF - End User Questions
Don’t anyone have an answer for this?
Geoffrey, can you expand on your explanation of leasehold improvements - not sure I understand fully. Do you just mean that over the life of the asset, its value will occasionally increase?
