Hi Expert,
Fixed assets threshold is not working in ax 2012 r3.
I have done related setup for threshold.
Please help me.
Hi Expert,
Please help me.
I’m afraid you won’t get any answer unless you explain your problem. “Is not working” is not very specific.
I Agree with Martin. You should specify what is not working…
Theory:
If you are acquiring an asset with the cost price that is lower than the threshold amount, system should not consider this asset for depreciation.
In AX2012: If you are acquiring an asset through acquisition journals, you would need to manually go and unselect the “depreciation” check box against asset’s value model.
If you are acquiring the asset through Purchase order, this check box will be automatically unselected if the asset cost is less than the threshold value.
