FIXED ASSET DEPRECIATION
In the Fixed Asset module our client wants common depreication rates applied for groups. But in Navision every Asset has to be given the depreciation rate seperately. So I cannot say calculate depreciation for all vehicles where the common rate of depreciation is say 10% Any suggesstions to overcome this Tks
Can you give some more information. What depreciation method are you using? If you are using Straight line and manually specifying the % rate, then all you need is some field on the header to group these together. You could, for example, use the search description.
