How to change Depreciation percentage from one percentage to another percentage after run the depreciation
EX: ‘A’ Asset has acquired and run & posted depreciation for one year with 10.34 percentage, now if we want to use another value module with new depreciation percentage 6.12 for existing asset, how to setup the same.
1- Go to the Fixed Asset master form select the Asset and then click on Value Model. Highlight the status field and change it to Closed. This will stop all the transaction getting posted.
2- Create a new Value Model and assign the same to the fixed Asset.
3- Now the copy the net book value of the Asset which was run using the first value model.
4- Post an Acquisition journal with the same net book amount.
5- To check the transaction against the Asset use Fixed Asset History report which shows all the transaction that were done till now.
… if you find the post helpful, please verify solution …
As suggested, you can just follow these give below steps
this is a simple process, instead of you changing the dep profile…
old Acquisition can be done by taking the net book value of the asset and sale it with the same cost (here there will not be any effect as the amount will be same)
Using the same net book value new acquisition can be done.
