i have to filter the data in the form based on the value of enum.
For Example if my ENUM consist of three values A,B,C
in the form i need the filter all the records having the enum type A in the table .
Can some one suggest how to do it…
hi harish,
You should add an init method in your form datasource, where your want to filter, with the following code
this.query().dataSourceNo(1).addrange(fieldnum(your_table,your_field)).value(enum2str(your_enum::your_enum_value);
hope it helps,
regards,
Thomas
Thank you,its working
