Hello All,
I just found the following statement doesn’t work, as the “firstOnly” part is returning more records than 1, as I debugged.
===X++ select statement=========
while select field1, field2
from Table_A
join * from Table_B
where condition_002 between Table_A and Table_B (table_A to Table_B is 1 to 1 by foreigh key condition)
join firstOnly * from Table_C
where condition_003 between Table_B and Table_C (table_B and table_C could potentially be 1 to Many, but the condition only wants to get the first record, as we don’t want to expend the whole data set size.)
After checked the MSDN documents at https://msdn.microsoft.com/en-us/library/aa661012.aspx, it turns out "The firstOnly keyword does not guarantee that a maximum of one record is retrieved by an X++ SQL select statement. " And, at https://msdn.microsoft.com/en-us/library/aa861766.aspx, at “Using the firstOnly Qualifier” section, it says The firstOnly qualifier does not guarantee that only one record is returned. For more information, Do not use while select firstOnly.
OK, so go back to the X++ select statement, what should I change, if the original idea to get ONLY 1 from table_C, can be realized?
Thank you,
Kwen
