Finished Goods RAF
I work in a Construction Chemicals producing company using Ax 2009. In a day we have lots of batches to close (RAF) in powder section ,say 100 Batches. It consumes lots of time and Please can you suggest any shortcut options for that ?
You can do it through the periodic update function depending upon the triggers to declare RAF and how you report. My main question would be your process and why you have lots of batches. Ultimately if you need them you need to RAF them. It should not take a lot of time, you press update and then OK. However if you are then defining batch numbers, quantities, time, material etc. you need to look at the process.
