Is there eny function or method that will lookup the firts and last value of any given base enum
ex. I have a report dialog where filtering on item type is possible (From Item type / To Item type),
I want to default the values to the first and the last value in this enum
I have done some code in job.Please check that and modify as per your need.
StatusIssue status; // StatusIssue is the enum for which I printed the first and last element label
int i,_max,Eid;
str value1;
DictEnum dictEnum;
Eid = enumName2Id(“ABCModel”);
dictEnum = new DictEnum(Eid);
