Hi ,
Find(’-’) go first----------------- Find(’+’) go last
Is ther anything in navision to write find second record
or find third record …or find fourth record … or find fifth record
I know i can write this coding in indirect way … if there is anything like this please let me know
thank you
stryk
October 14, 2008, 11:29am
3
Hi!
To be a little bit more specific:
FIND(‘-’) retreives a result-set (all records in the filtered range) and sets the pointer to the first record from this set.
FIND(‘+’) retreives a result-set (all records in the filtered range) and sets the pointer to the last record from this set.
IF you want to ONLY retreive the first or last record of a filtered range, then it would be the FINDFIRST or FINDLAST commands.
Regarding your questions: No, there is no command for e.g. getting the 4. record from a set, or something. You have to program it, for example like
Record.SETRANGE(…)
Record.FIND(‘-’)
IF Record.NEXT(3) THEN; // sets pointer 3 steps below, 1 + 3 = 4th record from top
This works also the other way around:
Record.SETRANGE(…)
Record.FIND(‘+’)
IF Record.NEXT(-3) THEN; // sets pointer 3 steps above, 1 + 3 = 4th record from bottom
Hope this helps you.
Jörg
stryk
October 14, 2008, 11:35am
4
Hi David!
You’ve been quicker [:)] But are you sure it will work with FINDFIRST? At least with SQL Server you’ll get a problem; here it should be FINDSET (or FIND(‘-’)) …
Best regards,
Jörg
yes you are right, it shoudl have been findset. (I will edit the post to indicate this.)
DenSter
October 14, 2008, 12:46pm
6
It works (and it shouldn’t, it should error out, to force developers to make these decisions correctly), but it’s not the right way.
Hi ,
thanks for you all … i think the 2nd reply will work …thanks again
hi all ,
this the solution …posting it so that we can know the result
rec.FIND(’-’);
IF (rec.NEXT(1)=1) THEN BEGIN //// then the 2nd record { 1 will point you to 2nd record and 2 will point you to 3rd }
BarcodeNo2 := rec.“Barcode No.” ;
END;
rec.FIND(’-’) ;
IF (rec.NEXT(2)=2) THEN BEGIN ////////////////// this is the 3rd record
BarcodeNo3 := rec.“Barcode No.” ;
END;
robertc
November 18, 2008, 9:54am
9
You can force an error (for any NEXT not based on a set established by a FIND/FINDSET), by setting in SQL:
UPDATE [$ndo$dbproperty] SET diagnostics = 81920
Setting the value to 16384 instead, writes an error entry to the Client Monitor, but does not actually throw an error.
