How to find out EP server location in AX 2012, Mean , For Example I can see EP Page url from System Administration > Setup > ENterprise Portal > Website
So How can i get the Websites IIS is Server location
Can anyone help me
Can you be more precise on y dou you need the location of the EP site?
For EP web parts or for deploying a new custom web part you can find it in this location.
*C:\Program Files\Common Files\microsoft shared\Web Server Extensions\14\TEMPLATE\FEATURES*
path would be the same path as of the web application under which the EP site is installed.
Thanks Adand,
I need to restart the IIS but I dont know in which server the EP IIS is installed, is there anyway to find the it. I hope you understood my question
The answer will be , the server on which SharePoint server is installed?
OR
Go to SharePoint Central Administrator and under Application Management>> Site Collections >> View all Site collections.
Here check if you can identify the EP web site URL.
