Is Financials 2.01b Server able to run on Windows 2000 Server
I haven’t tested it, but I believe it should work fine. I know that all the older Financials clients work fine in a Win2000 Professional environment. Financials Server is a “standard” Windows executable and since Win2000 Server is designed to be backward compatible, there is no reason to think any of the older versions of Financials should have any problem running in that environment. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
Thanks Dave. I spoke to a colleague of mine and he said he had a few clients running Windows 2000 Server with Navision 2.01B Server without any problems.
