HAVING TROUBLE SHOWING THE GENERAL LEDGER ACCT NAME IN THE LINES, CURRENTLY ITS JUST SHOWING THE ACCT NUMBER.
I’M NOT ABLE TO SUM. MY ARGUEMENT PANE IS EMPTY
OK, I figured out #1. #2 is my issue. I can’t get the summing correct. I created a new node, made it a calculation, but cannot ascertain the syntax for the summation. Information statest that I should use the ID # in the Arguement Pane, but my pane is empty.
