financial statement
hi all
After creating structure desinger , amounts are not flowing in to report, only report structure of Balance sheet is priting.
wht setup is required to take reprot of balance sheet structure with amounts.
Hi Anthony,
You make sure that whether you have set up Totals for the Line Items in the Chart of Accounts, which were designed in the Balance Sheet. Unless and until you do not set up those totals in COA , the report should be empty (i.e. no amounts will be printed on the Report).
