Hello!
I have a problem with structure designer: there are empy rows in BS when I print the report. These empy rows are before line which has type: structure. Can anybody help me?
An.
Hello!
An.
Hi Annie,
This is because the structure you are using have spaces inside. When you open the row definition where that structure refers to, there are lines where a row has a “line break position” = before or after. Hope this helps.
Best Regards,
Carol
Hi Annie,
This is because the structure you are using have spaces inside. When you open the row definition where that structure refers to, there are lines where a row has a line break position is equal to before or after. Hope this helps.
Best Regards,
Carol
Hi Carol!
I tried Line break positions but it doesn’t help.
An.
