Financial statement Dimension wise
How to design the P&L statement dimension wise? In the report, I’m able to get the account and one dimension. If I have to get more than one dimension, how do I do that.
For example:
Account
Dimension 1
Dimension 2
Dimension 3
Please help.
Sandeep
Mention your Ax version to have the correct answer , I assume that you are working on the Ax 2012 .
Did you configure the Dimension set as per your example - Dim1+Dim2+Dim3 and attach the same in the Primary dimension set and secondary dimension set in the Row definition of financial statement and run the report.
