Financial Statement configuration
Hi ,
I am trying to configure the Financial statment , when i take print preview system shows the 3 columns
Ledger name Current year balance Previous year balance
1111 2000 2000
In 3 fields it is showing ledger name and balances , but In the Previouse year balance is showing wrong .
My Configuration :
In the lower grid of Financial Statment form , in the Overview tab,
Column Name Column type
1 Ledger Name Main Focus code
2 Current Year balance Current
3 Previous year balance Current
what is the problem and where i need change the parameter to get last year balance correctly. ?
Look at the date interval code in the setup tab
Hi Ameen,
Have you checked the dates when you generate the report?
Best Regards,
Carol
Hi Ameen,
For column Previous year balance , check Transactions tab and be sure the check box include closing un flagged
BR,
Mohamed Salah
