Currently using Navision (4.0 SP3) and after following the above menu path there is function button below and when choose send to excel, navision throws a CAL/Programmers Error. Has anyone came across it and if yes what was the solution to it. I am using MS Office 2000 Standard with SP3.
First, try a reset of the PC. Sometimes Office and Navision go in tilt with those things. If this doesn’t help, I think it the version of Office that is to old.
Nav is pretty stable around there, the call indicates that code was developed for one version of an automation, but when you call the code another version is being used.
Check the automation controller, and see what version it is. I think Kriki is right in that your version of Office might be too old
