Reposted from the Sustained Engineering blog (http://blogs.msdn.com/microsoft_dynamics_nav_sustained_engineering/archive/2008/02/26/index-usage-query.aspx)
The column “No_Of_Updates” basically shows you the cost of this index, since every update requires a lock as well as a write to the database. The next column, “User_Reads”, shows you how often this index has been used, either from the UI, or by C/AL code. Compare these two, and you have way to compare the cost against the benefits of each index, as shown in the column “Cost_Benefit”, which is simply “No_Of_Updates” / “User_Reads”. The column “Last_Used_For_Reads” shows you when an index was actually used for reading.
The query sorts the indexes by “No_Of_Updates”, with the most updated (most costly) index first. At the last line of the query you can change the sorting to “order by Cost_Benefit desc”, and you are likely to see a different picture.
The data shown by the query is reset every time SQL Server restarts. So if you have recently restarted SQL Server, then the query may not show you the most precise picture of how the indexes are being used over time.
IF OBJECT_ID (‘z_IUQ_Temp_Index_Keys’, ‘U’) IS NOT NULL
DROP TABLE z_IUQ_Temp_Index_Keys;
IF OBJECT_ID (‘zIUQ_Temp_Index_Usage’, ‘U’) IS NOT NULL
DROP TABLE zIUQ_Temp_Index_Usage
– Generate list of indexes with key list
create table z_IUQ_Temp_Index_Keys(
[F_Obj_ID] [int] NOT NULL,
[F_Obj_Name] [nvarchar] (128) NULL,
[F_Ind_ID] [int] NOT NULL,
[Index_Column_ID] [int] NOT NULL,
[Index_Key] [nvarchar] (128) NULL,
[Index_Key_List] [nvarchar] (MAX) NULL,
CONSTRAINT [z_IUQ_TempPK] PRIMARY KEY(
[F_Obj_ID],
[F_Ind_ID],
[Index_Column_ID]
Insert into z_IUQ_Temp_Index_Keys
select
object_id,
object_name(object_id),
index_id,
Index_Column_ID,
index_col(object_name(object_id),index_id,Index_Column_ID),
from sys.index_columns
go
– populate key string
declare IndexCursor cursor FOR
select F_Obj_ID, F_Ind_ID from z_IUQ_Temp_Index_Keys
FOR UPDATE of Index_Key_List
declare @ObjID int
declare @IndID int
DECLARE @KeyString VARCHAR(MAX)
set @KeyString = NULL
open IndexCursor
set nocount on
fetch next from IndexCursor into @ObjID, @IndID
while @@fetch_status = 0 begin
SET @KeyString = ‘’
SELECT @KeyString = COALESCE(@KeyString, ‘’) + Index_Key + ', ’
FROM z_IUQ_Temp_Index_Keys
where F_Obj_ID = @ObjID and F_Ind_ID = @IndID
ORDER BY F_Ind_ID, Index_Column_ID
SET @KeyString = LEFT(@KeyString,LEN(@KeyString) - 2)
update z_IUQ_Temp_Index_Keys
set Index_Key_List = @KeyString
where current of IndexCursor
end;
close IndexCursor;
deallocate IndexCursor;
– Generate list of Index usage
create table zIUQ_Temp_Index_Usage(
[F_Table_Name] nvarchar NOT NULL,
[F_Index_Name] nvarchar NULL,
[No_Of_Updates] [int] NULL,
[User_Reads] [int] NULL,
[Last_Used_For_Reads] [datetime] NULL,
[Index_Type] nvarchar NOT NULL,
[last_user_seek] [datetime] NULL,
[last_user_scan] [datetime] NULL,
[last_user_lookup] [datetime] NULL,
[Index_Keys] [nvarchar] (255) NULL
insert into zIUQ_Temp_Index_Usage
select
object_name(US.object_id) Table_Name,
US.index_id Index_ID,
SI.name Index_Name,
US.user_updates No_Of_Updates,
US.user_seeks + US.user_scans + US.user_lookups User_Reads,
case
when (ISNULL(US.last_user_seek,‘00:00:00.000’) >= ISNULL(US.last_user_scan,‘00:00:00.000’)) and (ISNULL(US.last_user_seek,‘00:00:00.000’) >= ISNULL(US.last_user_lookup,‘00:00:00.000’)) then US.last_user_seek
when (ISNULL(US.last_user_scan,‘00:00:00.000’) >= ISNULL(US.last_user_seek,‘00:00:00.000’)) and (ISNULL(US.last_user_scan,‘00:00:00.000’) >= ISNULL(US.last_user_lookup,‘00:00:00.000’)) then US.last_user_scan
else US.last_user_lookup
end as Last_Used_For_Reads,
SI.type_desc Index_Type,
US.last_user_seek,
US.last_user_scan,
from sys.dm_db_index_usage_stats US, sys.indexes SI where SI.object_id = US.object_id and SI.index_id = US.index_id
order by No_Of_Updates desc
go
– Select and join the two tables.
select
TIU.F_Table_Name Table_Name,
–TIU.F_Ind_ID Index_ID,
–TIU.F_Index_Name Index_Name,
TIK.Index_Key_List,
TIU.No_Of_Updates,
TIU.User_Reads,
case
when TIU.User_Reads = 0 then TIU.No_Of_Updates
else TIU.No_Of_Updates / TIU.User_Reads
end as Cost_Benefit,
TIU.Last_Used_For_Reads,
TIU.Index_Type
from zIUQ_Temp_Index_Usage TIU, z_IUQ_Temp_Index_Keys TIK where TIK.F_Obj_Name = TIU.F_Table_Name and TIK.F_Ind_ID = TIU.F_Ind_ID and TIK.Index_Column_ID = 1
and TIU.F_Table_Name not in (‘zIUQ_Temp_Index_Usage’,‘z_IUQ_Temp_Index_Keys’)
–order by Cost_Benefit desc
