FIltering the onhandstock items
Hi all
I have a problem in filtering the data.
I have created a dialog class with itemid field where i need to filter the data in inventsumtable(only stock available items)
My problem is availablephysical is not a field ,its a display method,how to filter the display method .
for example availablephysical method is
display InventQtyAvailPhysical availPhysical()
return (this.physicalInvent() - this.ReservPhysical);
display InventQtyPhysicalOnhand physicalInvent()
return this.PostedQty + this.Received - this.Deducted + this.Registered - this.Picked;
Thanks&Regards
Manjusha.D
what is your output and where you are trying to filter?
in Production form i am trying to bring that dialog class with itemid field from inventsum table where available physical should not be null
