FILTERGROUP and SETVIEW
Try it in the Sales Order form in the OnOpen trigger, no matter in the beginning or in the end of the trigger. First piece of code is fine. If I change the SETFILTER line with the SETVIEW line so that the code become:
FILTERGROUP(2)
SETVIEW(…)
FILTERGROUP(0)
This is expected to have the same behaviour as the first piece of code, but it is not. The filter is set, but it is visible and removable.
If I use the second piece of code, it seems to be OK, but still I’m worried, because theoretically it should do something else.
