Is it possible to get filter values from request page to report layout?
Example:
I have a No. filter on request page and when a user has chosen a value, lets say 144, then when you look at the preview of the report, then in the header section there is a filter No. in one column and chosen value 144 in another column.
you can use global variables for that issue. in the request page you can set the value for the global variable, which can then be read/used for filtering in the report layout.
