filter the value in EDT
in dialog Box i use the EDt “DocuType”.When i click the lookup it show all the valu…but what i want is to show the particular value …
Do you mean DocuTypeId?
Do you want to filter only few values? On what criteria you want the filter?
How did you build the dialog?
yes…i build dialog like that.
dg1 = ret.addField(extendedTypeStr(DocuTypeId), “DOCUTYPE”);
that tells how you added the dialog field, but not how and where the dialog is build?
public void dialogPostRun(DialogRunbase _dialog)
FormComboBoxControl formControl;
super(_dialog);
_dialog.dialogForm().formRun().controlMethodOverload(true);
_dialog.dialogForm().formRun().controlMethodOverloadObject(this);
hi kranthi,
when i click this doesnot override lookupmethod
