Filter rows
How do I filter rows in a table? On a form I want to only show that rows from the Sales Invoice table, where the Post Desciption are bills. How can I do that? I hope you will understand me!
where are you tring to do?
manually in forms/tables or at run time through coding?
If manually, select the field in table/form, press F7 and your value
If in coding,
TableVariable.Setrange(Description,‘Bill’);
Check this out
http://dynamics-ax-live.blogspot.com/2010/03/how-to-filter-records-in-form-by-code.html
Check this out
Lookup the SETRANGE and SETFILTER commands.
