FILTER IN DISPLAY METHOD
I’ve two queries,
(1) I’m having a grid in form,which has a field named “Travel” Which is a **DISPLAY method.**If i want to filter records using Travel field.how can i do it… to say it simple…How can i filter recs in a DISPLAY method?
(2) Same Case for a REPORT, IF i want to display recs using the field “Travel” in a report,how can i do it.
In both the cases i’m displaying rec from the “PSASchedEmplReservation” Table.
Please Suggest Solutions.
Rajee
1)Filtration can be done on a field only.It is not possible on a display method.
2)If you want to display the data of a display method then the same logic needs to be written again on Report as well.
Vinay
Hi Rajarajeshwari,
Check this link it may help you…
https://community.dynamics.com/product/ax/axtechnical/b/matrishmangal/archive/2010/05/14/adding-find-92-filter-functionality-on-display-method.aspx
Naresh Kolli
