I’m working on adding a new dataitem to our Pick List report to show all remaining unpicked components from the RPO. I want to be able to filter out any components from this dataitem that exist in the Warehouse Activity Line dataitem from the same report. I’ve tried several iterations of SetFilter/SetRange on the various triggers of the report but they either don’t do anything or only partially filter the list. Thanks for any help you can provide.
I came up with a solution to this by creating a new boolean field called TempPick in the Prod. Order Component table. Then in the OnAfterGetRecord trigger I check to see if the Component exists in the Warehouse Activity Line, if it does then I set the boolean field to TRUE. Then in SSRS I filter on where the boolean field = FALSE.
I probably made this too complicated, I’m still curious to know if there was a way to do this by using SetRange somewhere.
trigger OnAfterGetRecord()
var
PickDoc: Record "Warehouse Activity Line";
begin
TempPick := false;
PickDoc.SetRange("Source No.", "Prod. Order No.");
IF PickDoc.FindSet() then begin
repeat
if "Item No." = PickDoc."Item No."
then begin
TempPick := true;
end;
until PickDoc.Next = 0;
end;
end;
