I have added one column to InventTable.called ItemNumer.
when i select some item from SalesLine. then as item qty = 0, price & unit gets fill with corresponding values.
BUT problem is with this field i have added, value of this field is not getting fill in this salesLine
so can you suggest where to add code to fetch this value?
Thank You.
