I am trying to use the Fill Utility to do a mass update to change the value to 10% in over-delivery and under-delivery field under Item Details->references tab, in Purchase Order.
After selecting all items and entering the new value then clicking ok. The window just disappear and no changes were made. Is there some limitation to this?
This feature will be available only if you enable configuration key (which you have done already) and security key. Name of security key is ‘AdminFillUtility’ and configuration key is ‘SysFillUtility’.
i noticed finally that it was not available in the tables added by a partner addon solution, while in standard tables like customer it was functional by doing the standard things mentioned here in the posts.
