FILE.Copy problems with timig...
Hi I’m using FILE.Copy to “create” a new WORD-document from an existing one. My problem is, that I can’t get Navision to see the newly created document unless I close the form??
At the end of your code, do a RESET on the File variable, and then renew it to the current folder. Currform.UPDATE for some reason does not refresh file variables.
