We are on FIFO and I would like to get a report that actually shows the layers of the FIFO for each item (i.e. quantity, cost, total) so I can see what makes up my total balance. Does anyone know if this type of report is available?
Also, with regards to our monthly adjusting to physical, how do you do it when you can’t use the Physical Count Journal because of the timing of receipts, etc.? I was using the Item Journal and doing negative/positive adjustments, but that was a problem because it defaulted to the average cost versus the FIFO cost for the adjustment.
Thanks for the help!
