hi i am new to ax please help me in this
how can i add fields to an existing form
It depends on the form… most likely the answer is calling up the form and making your edits in Visual Studio and then redeploying… Which form?
open AOT(Ctrl+D).
Create a Form in AOT>Forms,
open Another AOT>datadictionary>Tables select a table say CustTable and drag and drop it in your form’s Datasource.
Go to Form design and create a Grid there(right click >grid)
now drag and drop the required fields from datasource>custtable>fields
save and open the form.
Hi Sruthi,
Its simple, If u interest I will take online classes with low cost on skype,
I will show you how to work on AX by using Teamviewer
contact : sekharg1980@gmail.com
Sekhar G
Hi Sruthi,
Its simple and basics in Ax., …create table with required fields,
Go to Form you need to add
Drag YOU Created table to Form DataSource ( u will find when you expand form )
Go to design in form , Expand ----right click on design add group
right click on group ----add grid
drag fields from Form Datasourse to grid .
save and open
Ravindar Reddy
