FIELDS
Dear all,
what is the difference between flow fields and flow filter …
With regards,
R.Ramanathan
A FlowField is displaying a calculated value based on the CalcFormula of the FlowField. So it does not contain any data!
A FlowFilter is used in the CalcFormula of a FlowField. In a FlowFilter the user can enter a filter string which will influence that calculation of the FlowField it is used in.
So both are actually no fields. Where as a FlowField generally will display a value related to an individual record (like for example the Balance field for a customer), a FlowFilter is actually a table attribute as it’s value will influence the value of a FlowField on all records.
Hope this helps.
Did you already read the technical online help on these topics?
