Fields r missing in preview
hi all
in general ledger → parameters from
am not able to view few standard fields sucs as MAXroundingdiffMST, MAXroundingdiffMSTSecond and etc
whn i look into tables,the fields r avl, but whn i open table to view the data its showing only one filed MAXroundingdiffMST,
same situation in parameter form also not showing the fields
in propertise its set as visible only
can anyone suggest me some ideas.
thanx in advance
Any changes to the table/form? Check whether the fields exist in General field group in the table?
hi kranthi
thanx for ur reply, am not any changes in table or form level
its standard.
Hope you don’t have any security issues…
am the administrator of tat instance
Firstly, Check whether you have accidentally hid those fields on MorphX IDE?
If they are not available on table, table might have been altered.
Both the fields are available in LedgerParameters table and would be visible in general ledger - Parameters form.
in configuration i forgot to select euro currencies and another one
tats y i faced this pblm…
thank you all guys :slight_smile:
