when i run the table "G/l Acc."Table -15, i found fileds-Dept.code & Proj.code , but when i opened it in design mode , i didnt find these fields. How it is possible ???
Plz help me…
Regards
Venu…
Plz help me…
Regards
Venu…
These fields are called “Shortcut Dimension 1 Code” and “Shortcut Dimension 2 Code” or “Global Dimension 1 Code” and “Global Dimension 2 Code”.
The captions of these fields are being determined at run time according to the global dimensions assigned in the General Ledger Setup.
The CaptionClass property of the fields is being used to replace the caption at runtime to the values defined in the Dimension setup.
I strongly advice to not play with these fields unless one fully understands the dimension concept.
Thanks Thomas…
Please verify the solution by clicking the green “Verify Post” button in the post which helped you to solve your problem.
